318is (m42) O2 Sensor question
  • royalflush313
    • Mar 2004
    • 2070
    Does the O2 sensor for 318is have 4 wires or 3 wires?
    I need to find out which O2 sensor to buy (non-oem, as they are overpriced...).
    I found that the Bosch O2 sensor for mustangs and such (item # 13942) have 3 wires and can be had for significantly cheaper - but if my car comes with the 4 wire one, I need to look again...
    Thanks!
    ~ Go Canucks Go! ~
  • kowalski
    • Jan 2005
    • 1791
    4 wire, but 2 of the wires are ground, and can be joined with the 3rd wire.
    i however found a 4 wire, but i lost the bill with the part #:(
    • bebes2k
      • May 2004
      • 37
      hey, i used an NTK o2 sensor in my 318is. it works like a charm, i replaced it when i purchased the car and was going through possible parts that could have caused it to run so bad.
      it runs great now. i used part number ntk-21027 which is a universal 4 wire o2 sensor. significantly cheaper than the rediculous oem fit. i purchased this in vancouver from Bow-Wow auto parts, they have great prices.
      best of luck.
      • kowalski
        • Jan 2005
        • 1791
        best of luck.
        maybe i have an NTK... that might be why we could find a bosch one... do you remember how much$they wanted for it?
        • bebes2k
          • May 2004
          • 37
          I paid about $75CAN for the universal NTK part number listed above. I believe the retail price on it was over $135. I have a cash account as I work for a local body shop.
          • royalflush313
            • Mar 2004
            • 2070
            best of luck.
            Thanks, I'll look into those!
            ~ Go Canucks Go! ~
            • kowalski
              • Jan 2005
              • 1791
              yeah, i got mine for 70 or 75$ i just get get a huge discount because im friends with the guys at lordco. then i started working there and i get another 20% off of that almost 50% discount:)
              • nickmp0wer
                • 1427
                my car has been getting low gas milage latly so i searched for it on google. seems like they dont make it anymore
                http://ngk.com/results_cross.asp?pid=21027&x=35&y=2
                but i guess its been replaced by this
                http://ngk.com/more_info.asp?AAIA=&pid=18288
                is that similar to how yours looks? looks a lot different then the bmw one i think
                • kowalski
                  • Jan 2005
                  • 1791
                  i think that is a generic picture of an 02 sensor. not the one you would be getting.
                  • nickmp0wer
                    • 1427
                    well if that is the right one, $44.95 is pretty good
                    • nickmp0wer
                      • 1427
                      I ordered it, and the one i got pretty much looks like this
                      [img]http://ngk.com/productImages/1/12A%2Ejpg[img]
                      i guess i will try it though. There is a black wire, two white wires, and a grey wire, i guess i just connect those to the same colors on the oem harness?
