Transmission Grindage..yet another problem
    Finally got my car back from the alignment shop and all is well with my suspension now.. BUT
    When I went to pick the car up the past 2 times I noticed that I kept grinding 2nd - 3rd and sometimes 4th and it's a pain to get it back into 1st until it gets warm or I had driven it for about 5 minutes.
    Now I do know that the output shaft seal is bad and has been leaking but I didn't think it was too bad, I haven't had the chance to check the MT fluid either. It has also been pretty cold the past couple of days (25-17 Degrees). What is most likely the culprit? I plan on checking the fluid and replacing the seal when I get back from visiting family for Christmas but I want to make sure I'm not missing anything.
    I recently filled the transmission up this summer with 75w-90 Lucas gear oil when I did the transmission swap and the spots of gear oil on the driveway are very small.
    you'r probably low on fluid then. small spots on the drive way add up over the months...
