weird tug/jerk while i drive
  • e30zues
    • Dec 2012
    • 26
    OK so for like the past month or so I been getting this tug/slight pull and it's pretty annoying while I'm driving. I've switched sparkplugs /wires/cap nrotor /fuel filter/ cleaned the injectors but can't seem to get to the source people say it's my gaskets others say it's my fuel pump so2 if anyone can help me out highly appreciate it
  • E30Gus
    • Jun 2008
    • 781
    Is she hot? I like getting jerked while I drive. :giggle:
    Be a little bit more specific like is it dropping rpm's?
    Intake leak possibly...do a smoke test.
    Oh and welcome!
    • e30zues
      • Dec 2012
      • 26
      E30GUS Lol Dayum u busting my balls well since the jerk started my rpm gauge was going crazy when I floored i t I don't see the rpm go down u can just feel the jerk/tug back when u are driving
      what's a smoke test.?? O.o
      • E30Gus
        • Jun 2008
        • 781
        Start by searching R3V, there is a wealth of knowledge/problems on here that have already been talked aboot.
        Check your fuel rail pressure to make sure it isn't one of your pumps.
        Could be an intake leak in which a smoke test would tell all.
        Do you own a Bently manual? You have an E30=you need a bently.
        Then search again!
        • onthefly
          • Aug 2012
          • 69
          Idle air control valve i have the same problam rite now but there not cheep
          Those who stand for nothing will fall for anything. 1985 e30 325e chipped 4:10 lsd forged control arm bushing and old ass bbs weaves. 1966 ford galaxie 500 XL 390. 1982 e21 320i........not running. :wgaf:
          • hahaitzskippy
            • Oct 2012
            • 116
            the issue is worse for me between 1-2 RPM when cold.
            not as apparent when it is warm or hot but it is there.
            only happens when im holding the gas so when the RPM is between 1-2. as if the car isnt sure how much fuel to pump into the system or something...
            2007 Mazda CX-7 (red TURBO!!)
            1985 BMW 318i.... beige!
            2007 Suzuki GSX-R 600 (red)
            previous cars
            1) 1994 Isuzu Trooper (blue)
            2) 2005 Scion tC (panda w/ CF)
            3) 2001 Toyota Avalon (silver)
            4) 1988 Nissan Pulsar XE (T top in red)
            • onthefly
              • Aug 2012
              • 69
              SYa thats the same thing my e30's doing i replaced my iac with one from a junk yard and it solved the problam for a few month's but then that one took a dump on me and now my cars doing the same exact thing but be warned as i have found out to buy one new is not cheap but most of them have life time warenty and your lookin at around 200 bucks depending on where you get it
