blower fan stopped working.
  • peytonracer4
    • May 2011
    • 524
    i know this is a common issues kinda. but is it really possible for the unit to fail in a matter of 30 minutes?
    it's worked fine on all speeds until tonight. it started squealing quietly and progressively got worse. now the only fan speed that works is 4. the highest setting.
    this all happened over the course of about 30 minutes to an hour. it was totally fine and silent until tonight.
    is this the sign of a failed blower? why is it only working on one speed?
    where's the cheapest place to get one assuming it's failed?
    thanks
  • KVF
    • 297
    If it works on one speed it's probably the resistor, not the motor.
    • peytonracer4
      • May 2011
      • 524
      Well the blower started squealing like a crazy mouse before it went on one speed. An hour before all was well.
      • MoreMayhem
        • Feb 2012
        • 649
        Just replaced mine. It went from quiet to unbearably squeaky in about 15 minutes. I didn't replace the resistor, it looked okay. Cheapest would probably be pick n pull.
        I almost went that route but found one at BMA for about 170. Behr/Hella brand.
        • peytonracer4
          • May 2011
          • 524
          i don't really plan on getting it from a junk yard. a 20 year old part is a 20 year old part in this case. a door handle is different than an electronic part.
          so did you have the same symptoms as me? you mentioned increasing noise in 15 minutes. did all your fan speeds not work except for 4?
          • rwh11385
            lance_entities
            • 18403
            Sounds like the fan relay maybe. Turn the fan to 4 and turn off the car and get out to see if the fan is still blowing.
            This has happened to two of my E30s.
            • peytonracer4
              • May 2011
              • 524
              So what's the solution? Replace the relay with a new one? Where is it located?
              • rwh11385
                lance_entities
                • 18403
                Solution if that's the problem: Replace the relay. I forgot how much it cost, I just had one lying around. But maybe it's like $15ish??
                It took like 3 minutes to fix, half the time was spent opening the hood. (It's in the fuse box)
                Confirm that it's the problem first, but it looks like this: http://www.turnermotorsport.com/p-53...n-colored.aspx Mine was orange at least.
                Maybe this: http://www.turnermotorsport.com/p-11...most-bmws.aspx
                • long tall eta
                  • Jul 2010
                  • 1536
                  just my 2 cents but if i'm not mistaking these fans are balenced and if yours has the balencing pieces missing this might lead to squeeling. or maybe the bearing is shot. also if it's not in there just right, it will work but make noise. i always test run mine before putting the shroud cover back on.
                    The fan squealing means that either the bearings are gone or an impeller failure has occurred. In either case the fan gets replaced.
                    • peytonracer4
                      • May 2011
                      • 524
                      so i'm going to jump the gun and pretty much assume that the blower is shot and needs replaced.
                      where's the cheapest place to get a new one? BMA? it's an A/C equipped car.
                      i still have the single fan speed problem. it seems like it's the relay. is it a physical relay that gets stuck? we have a 4runner that has one and if i slam it on the ground it works again.
                      it seems REALLY weird to me that the relay and fan both took a crap in a matter of 30 minutes. coincidence?
                        If the fan suffered and impeller or bearing failure, full current to the motor may be required to turn the fan. Which could disable the lower speeds. Worst case, both the fan and resistor could be bad or the fan and fan switch could be bad.
                        • KVF
                          • 297
                          Your problem may be larger than mine, but fyi... When my resistor went I thought it was the fan because it squealed like a stuck pig. However, a buddy convinced me to pull everything out, hit it with some contact cleaner and compressed air to clean it up and then check operation. My unit has been operating as intended for two years now, and all I changed was the resistor. Clean it all up first and see what happens.
