I just replace my OE pump with this unit but noticed that once installed the PS belt doesn't sit straight on the pulley. I'm positive I installed it correctly. The remanufactured unit was smaller and did not require the same brackets as the OE one. Will this cause problems later on?
ZF remanufactured steering pump
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Tags: None -
I don't know why the remanufactured unit couldn't be made to the same specs as the oe one.Renting my rear wheel bearing tool kit. SIR
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
