transmission mounts
  • azzkikr
    • Jul 2005
    • 156
    transmission mounts
    Are the transmissions crossmember/mounts on the 318i the same as on the 325i. On real OEM them come up as the same part number for the crossmember but the image looks different. The reason I ask is because I can get one off the 318 but I need one for the 325i. I would assume they are different because I would have figured the transmissions have different sizes. Anyone know for sure?
  • kowalski
    • Jan 2005
    • 1791
    i believe the tranny's are the same size. the ones on my 318 are little cylinders witha bolt sticking out of each end.
    • azzkikr
      • Jul 2005
      • 156
      If the trannys are the same size does this also mean the shift linkage is the same also?
      • kowalski
        • Jan 2005
        • 1791
        yeah.
