clutch pedal stuck to floor
  • hooken m
    • 1537
    hey guys so im just about done with my 24v swap and i bled my brake lines today perfectly fine and have excellent brake pressure. so next step was my clutch line. so im bleeding it and got all the air out and fluid comes out fine but the pedal still doesnt build pressure. btw the clutch slave has under 2k on it. it was originally on my e36 m3 and i changed it before i pulled the engine and trans. the clutch master cylinder idk how many miles it has, but before tearing everything apart my clutch pedal worked fine.
    help me out please!
    Originally posted by evandael
    a car is a car. call it a dildo, i'd still drive the hell out of it.
  • SmokeE30
    • 1730
    If its not returning there has to be some air still in there or a leak somewhere a buddy of mine had a hell of a time bleeding his clutch on his 328is he once had ended up looking fine every time but the clutch would still not fully disengage properly untill finally bimmer works fixed it by power bleeding it
    Shawn @ Bimmerbuddies
    Bimmerbuddies LLC
    717-388-1256
    2971a Roundtop Rd, Middletown PA 17057
    bimmerbuddiesllc@gmail.com
    • ADlBOO
      • 335
      You can try bleeding it again. When my clutch pedal dropped, changing the master/ slave fixed everything.
      I have friends who are EOD bro.
      That's awesome. I have friends who make coffee for a living, but you don't see me rocking out a bunch of lattes
      • AndrewBird
        The Mad Scientist
        • 11898
        Reverse bleed it with an oil can. Basically get a squeeze pump type oil can, hook it to the bleeder and pump fluid back up to the master. This will eliminate any air. There are a few threads on this. Search and you should be able to find them.
        • MoreMayhem
          • Feb 2012
          • 650
          On my e28 I had to remove the clutch slave cylinder, leaving the hydraulic line connection intact, and invert the cylinder so the bleed valve pointed upwards to get the air out. Don't do this with the pedal pump method. I used a pressure bleeder. Didn't have his issue on the e30 for some reason...
          • dnguyen1963
            • Nov 2011
            • 2651
            Go to Bavauto.com and search the video for how to properly bleed the master/slave cylinder.
            • hooken m
              • 1537
              thanks for all the input guys. ill def try to bleed it a bunch more tomorrow. just sucks that its suck a tight spot in the tunnel for me to get to the bleeder nipple. i will report back with progress!
              • bmwguy325is
                • May 2011
                • 1263
                Use starter at stop lights learn to shift with no clutch
                sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                • hooken m
                  • 1537
                  i tried bleeding it again and no pressure in the pedal no matter what i do. what could be the problem now. master cylinder?
                  • Hey_You
                    • Nov 2009
                    • 963
                    Try gravity bleeding it for a few hours. Just make sure the fluid level stays full. Look at your clutch master for any leaks. It takes awhile, but I can be done
                    85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
                    • hooken m
                      • 1537
                      ok so i swapped my clutch master today and i tried bleeding it and i still wasnt getting any pedal feel. cause im idiot, i had a clutch stop on the car which was stopping the pedal from going all the way down to the floor, but once i removed it and bled it 3-4 tried i had full pedal feel. problem solved lol. thanks for the input anyways guys
                      • dnguyen1963
                        • Nov 2011
                        • 2651
                        Simple solutions are often overlooked. Glad you got it figured out.
