Running In tank walbro 255 with external pump
  • FLG
    • Sep 2011
    • 3165
    Quick question.
    I've got an early model with dual pump setup. Currently run a 255 in tank and was just going to eliminate the stock external.
    But I have a brand new external pump sitting here...
    Would I be better off bypassing the external pump or installing the new external pump?
    This is feeding a 400+ whp turbo m20
    Last dyno session we had to cut short due to fuel issues.... I don't want that to happen again.
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
  • bmwdready347
    • Jan 2011
    • 586
    Was going to run same set up ,only the exsternal pump was a bosch 044 ,but the tuner guy just use in tank walbro
    • dnguyen1963
      • Nov 2011
      • 2649
      You have to compare the flow rates/pressures of both pumps. If your external cannot pump as fast as your internal that would create flow back pressure problem.
      • FLG
        • Sep 2011
        • 3165
        Thanks.
        So bypass the external.
        • dnguyen1963
          • Nov 2011
          • 2649
          Yes, the 255 should be sufficient enough.
          • Mr. Tasty
            • Jul 2011
            • 3421
            don't you have to find another pump carrier though?
            2014 Alpine White 335i MSport
            (Daily Driver)
            Full Mperformance Aero
            KW V2 Coilovers
            VRSF Catless Downpipes
            • FLG
              • Sep 2011
              • 3165
              Pump carrier for what? The in tank? No just had to shorten the metal line that the pump connects too. Soldered the wires to the stock connector. Done.
              As for the external bypass I have double barb fittings for that.
              • Mr. Tasty
                • Jul 2011
                • 3421
                so you by pass the return line too?
                (Daily Driver)
                KW V2 Coilovers
                • FLG
                  • Sep 2011
                  • 3165
                  No didn't have to touch the return line.
                  Original setup is return line goes into the tank connects to bottom of pump as seen here (bottom left)
                  Now it just goes in the tank. Pump connects just like old one to the output. Hose clamped it to the return line to hold it in place.
                  • Mr. Tasty
                    • Jul 2011
                    • 3421
                    nice, where did you find the pump the cheapest? One of my pumps is going out, and would rather not pay for the expensive bosch.
                    (Daily Driver)
                    KW V2 Coilovers
                    • FLG
                      • Sep 2011
                      • 3165
                      "tre" seems to have the best deal. I'm on my phone but if you don't find it I'll link you up later tonight
