Halp!
  • Wschnitz
    • 8089
    Halp!
    My blinker is retarded, Ive replaced the front bulb twice. no change.
    willschnitz
  • Simon S
    • Oct 2004
    • 3758
    Not sure if it's a similar issue, but I once had a nightmare of a time with one of my taillights.. and the issue was resolved by using a dealer/OE bulb instead of a "parts store" bulb.
    fuckin drove me nuts trying to resolve it..
    Try swapping left and right bulbs and see if the issue "follows" the bulb.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • Swanny
      • Mar 2012
      • 2834
      Socket might have gone bad. Had to change out one on my diving board this summer. Test the plug for the correct signal then test the plug with a bulb in place for proper resistance.
      Swanny!
      SUCKERS.
      • Wschnitz
        • 8089
        But if you watch it works fine with the Hazzards.
        willschnitz
          That could be a bad turn signal switch.
          • vert_this
            • Feb 2012
            • 395
            I've had the same issue on an e28 that I used to have and it was the socket itself. The bulb being replaced wouldnt fix it. Which you may want to first try? It was the front socket and what I used was a battery cleaner to clean rust off the socket itself. The battery cleaner is nothing more than a wire brush that I could stick down in the socket. You can buy them at walmart. It could be the rear one if water is getting in the trunk so don't be upset if you have to do both to repair the problem.
            • Komzorz
              • Jun 2011
              • 332
              I was thinking something along those lines too.
              '87 325is - Schwarz/Schwarz
              • Wschnitz
                • 8089
                Ill clean the sockets with a wire brush before i buy new sockets. Car is for sale so spending money isn't my thing.
                willschnitz
                • LivingLegend06
                  • Dec 2006
                  • 1604
                  Try this,
                  I don't see how it could be the switch, its just that, a switch. The relay controls the blinking and its the same relay that controls both right and left so that isn't likely to be the problem either.
                  Did you change anything before the problem started?
                    If the switch has a high resistance in either side, you will get a fast blink on that side.
                    • bastianshaw
                      • Jan 2007
                      • 2210
                      people used to do this on purpose i think it was a relay you changed...I need to use my blinkers more
                      • The München Monster
                        • Dec 2012
                        • 150
                        Me and my dad tinkered with the tail light for some reason one time, and this happened to me once on the road. Never happened again though. I hope yours is that temporary.
                        Celebrating 30 years.
                        1986 E30 Coupe, assembled in Munich, West Germany, 7/7/86. M10 5 Speed cruisin' through time and space
                        • saurey
                          • Oct 2012
                          • 71
                          I have this problem - my front left blinker doesn't work at the moment. The rear does and it's going fast but the front bulb is still lit up solid when the lights are on. I think I screwed something up when I installed my front left speaker because there is a birdsnest of wires under the dash/steering column and I hope I didn't bump the wrong one. Anyone know where these plug in underneath the dash? I'm about to take it to a mechanic but would rather not pay for something somewhat simple.
                          • bmw325csi
                            • May 2007
                            • 4045
                            my very similar problem was in fact the stalk.
                            harry/harout
                            • saurey
                              • Oct 2012
                              • 71
                              Can you elaborate?
