power problem
  • tommyboy
    • Oct 2004
    • 162
    update?
    • e30 gangsta
      • 3877
      thats it same thing happend to me.
      • StereoInstaller1
        GAS
        • 22679
        An alternator charges the battery by producing higher voltage than the battery. If you are at 12.5 V with the car off, your alternator will likely produce 13.5 or more. Typical of Automotive Alternators is 14.4 V.
        GL, HTH,
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • Il Duce
          Non-Mod M42 Modder
          • 5046
          Originally posted by tommyboy
          update?
          i've been procrastinating on changing the alternator because
          a.) i'm not sure if i have the correct spare alternator
          b.) not sure if the alternator is the problem
          i'm very confused.
          • Il Duce
            Non-Mod M42 Modder
            • 5046
            went out to the garage today to take a look at the car, and replace the alternator, and i used my keyless entry to unlock the car, but it didnt unlock, i had to open it w/ a key. needless to say, the car would not start. grrrrrrr. something is draining the power, but i have no idea what it could be! i just put a new battery in the car.
            • Il Duce
              Non-Mod M42 Modder
              • 5046
              well, the problem turned out to be my voltage regulator, and now i'm having the exact same symptoms.
              ugh. anyone have any ideas as to why my voltage regulator keeps going bad? do i have a bad JC chip or something? this is really getting annoying.
                • 37833
                The chip has nothing to do with the charging system AFAIK.
                Grover Beach, California
                BimmerHeads.com
                • Sean
                  • 5793
                  Possible short in wiring somewhere? Not enough to drain system, but overwork alternator?
                  - Sean Hayes
                  • Brew
                    • 3060
                    Did you replace just the voltage regulator or the entire alternator?
                    Check your voltage @ idle again.
                    '91 318is
                    • DanGillan
                      • Mar 2004
                      • 4061
                      do a drain test see if anything is drawing power while the car is off. it has to be your alternator man, just swap that thing out for a brand new one and i bet your problems go away. there's really not much it could be. did you check all your battery and or stereo power connections? make sure ALL the terminals are tight on the alternator, starter, batter, check all your grounds, just go over the basics, it really cant be anything complicated, dont over think it.
                      Dan
