Interesting temp gauge question
  • Mafiaracers
    • 353
    Cliff Notes:
    1990 325i coupe, auto, 105k
    water pump/t-belt/tstat job
    block drain (figured why not while I was draining fluid)
    re-fill with 2 gal dealer fluid and top-off w/ distilled water
    installed dealer w-pump and t-stat
    pre-filled all hoses prior to clamping down to respective locations
    bled system using bleeder screw, on an incline, using proper method/technique
    car came up to temp just as it should, bled just fine. my issue now is the temp needle. It reads exactly 1/8" past vertical (on the hot side) and stays there. Cabin heat is nice and toasty at idle and while driving....Burp it, bleed it, neutral and hold 2500rpm idle, re-circulate on with heat blasted, nothing....stays a hair over vertical. Even driving it, it won't climb or fall...idle, won't climb or fall...just parked on the warm side. Hell, even a temp gun pointed right at the housing shows a healthy 185*
    I don't know the temp number on the t-stat I pulled out of the car as isn't long since in the trash and I don't know the number on the dealer t-stat as I didn't bother to look at it.
    So, faulty t-stat? should I go find an 80*? Should I get a colder one? has the sensor gone bad? Head gasket is fine as the oil is as clean as ever...
    Thoughts?
    Thanks!
    Chris Woods
    https://www.facebook.com/munichmotorworks
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    Just over vertical is fine. If it bothers you that much get a colder t-stat.
    -Andy
      A steady state temperature of 185F would correspond to an 85C thermostat. That is acceptable, but a bit too high. Either they gave you the wrong thermostat, or it is defective. I'd change it out for the stock 80C thermostat (176F).
