bleeding the clutch
  • Schneider325
    • May 2004
    • 3818
    bump.
    • Schneider325
      • May 2004
      • 3818
      This is the vacuum pump I have.
      HELP PLEASEEE
      • Schneider325
        • May 2004
        • 3818
        bump
        copy and past picture in your browser if it dosn't come up
        • DaN
          • 1265
          If the resevoir is full, you gravity bled the slave with the bleeder pointing up. And still no pressure then I'd say the slave is shot.
          I had a similar problem. I wanted to replace the slave for preventative maintenance, the new one wouldn't bleed whatsoever. I popped the old one back in, and it didnt even need to be bled. Worked right away.
          You must have disturbed or damaged the seal inside. Try another one.
          • Schneider325
            • May 2004
            • 3818
            I think its something to do with me using the vaccuum pump. first I can't get any pressure to build up. Even with it off the car the gauge dosn't move what so ever when everything is hooked up.
            I'm suppost to pump and then open the valve, correct?
            I may have just have to buy the right tool and remove the top nut to the slave and turn it upside down, like I was going to in the first place.
            • Axxe
              • Aug 2004
              • 3355
              Open the bleeder valve, and open the fluid resevoir. Let it drip down. It's a PITA, took me 15 mins to bleed it on my own without a pressure bleeder. Be patient, once you have fluid dripping out consistently, close the bleeder, and pump the clutch pedal. Repeat.
              Keep it slideways!!
              • Schneider325
                • May 2004
                • 3818
                Thanks
                So, I should still be pumping the pedal even with my vacuum pump?
                  • 37828
                  Just do it the way I told you to a month and a half ago!
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • Schneider325
                    • May 2004
                    • 3818
                    Well god damn I already bought the pump. ;)
                    edit: I'm selling, returning the pump I bought to get a pressure bleeder.
                    • silversleeper
                      • Mar 2005
                      • 2032
                      ur at least half way there, i dont even know how to bleed the clutch, and i think my car could use a bleed.
                      Claus Luthe is my hero.
                      • Schneider325
                        • May 2004
                        • 3818
                        new pressure bleeder came in today. Tired it out and it was working like a charm. Fluid was coming out. I just needed to be paitence and do it for a while, while pumping the clutch inbetween. Well after about the third time I just got air....
                        I ran of out damn fluid!
                        Ordering some more and this problem is going to be gone!
                        • Schneider325
                          • May 2004
                          • 3818
                          Ok I THINK it is finally done, I just need some reassurance.
                          Pumped up the pressure bleeder and went under the car. Opened the bleeder and let the fluid out. Did this a bunch of times while pumping the clutch in between. The pressure came back!
                          The only problem is the flow of the fluid coming out. It's not like it was for the brakes, filling the whole vinyl tube. It was only streaming down one side of the tube.
                          I'm not sure if this is a problem since I have pressure back, but I just want to make sure. The clutch feels great. Not as firm as the brake thought, but its probably normal.
                          Do I have the ok to Go drive the car finally!?!?
                          • DaN
                            • 1265
                            Sounds good.
                            • PeaveyBassist
                              • Sep 2004
                              • 3511
                              Its good.
                              Will
                              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                              Welcome e30 (brilliantrot '90 325is) 12/23/06
                              DaveCN = Old Man
                              My signature picture was taken by ME! Not by anyone else!
                              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                              • BDSax
                                Junkyard King
                                • Mar 2006
                                • 3594
                                Unbolt the slave and flip it upside down from the way it sits inside the tranny. It does wonders. Once blead, reinstall
                                wow, bump from the past! THANKS Matt!!!!! tried to quickly bleed the utch in my m535i and it was a nightmare til i read this. I LOVE R3V!
