Starting issue and momentary loss of ignition loss
  • rodrigo
    • Aug 2007
    • 923
    Hi guys,
    Well, with the winter, I too have issues: first time with the E30 too. After 70,000 miles of ownership, I now have an issue when starting the car.
    In the morning when it is cold (we've had sub 30 degree mornings) I'll start the car, it cranks and it starts, only to die 1-2 seconds later. Then I'll crank it again, and it will start, go into a rough idle but settle out and idle normally after a minute or so.
    Then, I leave for work and start driving. I noticed that if I release my foot off the accelerator very suddenly, the tach drops down to 1000, the check engine light flickers on and I notice a momentary stall, but then it all goes back to normal like nothing happened.
    All of the above is when the car is still not at the mid-way mark on the temp gauge. That tach/CEL/stall symptom will happen as often as I want until the car has about 2-3 minutes of highway driving (65-75mph).
    I bought this car with 125k and now it has 192k. I've never replaced any O2 sensors or CPS: it has never needed anything. It did have a timing belt and shaft seal replacement at 185k with all new accessory belts and I also did new plugs, cap and rotor. Right not it could also use a set of motor mounts.
    In the time I've had it, this has been one of the most reliable cars I've ever had (I come from Volvo-world). This is the first real issue that has ever come up with it and I'd like to resolve it so it keeps going... I'm almost at 200k!
  • EyExR
    • Jan 2011
    • 959
    Do a stomp test and check codes...
    Sounds like a vacuum leak to me. ...not that the stomp test will reveal that. But I would check that first. Smoke it if you can.
    I would also clean the MAF, ICV and adjust the TPS while at it. I would also check or replace the CTS. Take it from there...
    How is the overall health of your engine? At 200k I would definitely want to do a compression test and leak down test and see what's up. When it's cold and you start your car any worn gaps in your piston rings and valves will cause compression loss and hence a rough cold start.
    A cheap and sometimes cheerful solution is to Seafoam your car and try to burn off carbon deposits.
    Do you have a cold start valve?
    Also try to spray some wire dryer in the distributor cap. You could possibly have condensation buildup in there...
    good luck
    My 325iX DIY Threads:
    Front Wheel Bearing Replacement
    325iX Rear Subframe Bushings and MUCH more w/pics!
    325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
    • rodrigo
      • Aug 2007
      • 923
      What product do you guys recommend to clean the ICV and the MAF? Brake cleaner?
      I've checked for vacuum leaks and did not find anything. Went around with the can of ether on the hoses and connections.
      I did not even realize there was an adjustment ont he CPS...I'll be reading the Bentley later today.
      Thank you :)
      • SpecM
        • Oct 2005
        • 4531
        I've had this problem for a couple months now
        I've fixed vaccum leaks, cleaned intake/ICV/AFM, replaced cap/rotor/plugs/wires, CPS, fuel pump relay, AFM and DME
        still does it
        1989 cirrisblau-metallic 325i
        • rodrigo
          • Aug 2007
          • 923
          still does it
          Funny you say that: we have the same car. Mine's also a 1989 Cirrusblau Metalic 325i. :shock:
          • SpecM
            • Oct 2005
            • 4531
            well thats the problem then! ;)
            I think the issue is an intermitant loss or interuption of timing data to the DME
            do a stomp test and report back
            • SpecM
              • Oct 2005
              • 4531
              my thread: http://www.r3vlimited.com/board/showthread.php?t=270938
              • EyExR
                • Jan 2011
                • 959
                Thank you :)
                I usually use MAF cleaner on the MAF and carb cleaner on the ICV.
                Adjustment is on TPS...
                • rodrigo
                  • Aug 2007
                  • 923
                  I read that wrong. Thanks for correcting :)
                  I'm going to research what the stomp test is.
                  • dnguyen1963
                    • Nov 2011
                    • 2649
                    Don't bother to do anything else until you have a smoke test done on the car! Spraying a can of ether around the engine will not reveal much. Once you eliminate the possibility of vacuum leaks then you can go on to other stuffs. To do a stomp test...turn the ignition to position 2 (do not start the car) then quickly depress the gas pedal fully 5 times...look at the check engine light and count the flashes. It would be something like 1 flash, 2 flashes, 2 flashes, 1 flash. Your code then would be 1221. You might have to do this procedure multiple times before the CEL would flash.
                    • SpecM
                      • Oct 2005
                      • 4531
                      Bump
                      • rodrigo
                        • Aug 2007
                        • 923
                        Bump
                        I'm going to try and get this done today...I'll be cleaning the mentioned parts first and seeing how it goes.
                        • SpecM
                          • Oct 2005
                          • 4531
                          Did you come up with anything?
                          • rodrigo
                            • Aug 2007
                            • 923
                            I did not, but it no longer has the issue. It seems to happen more during the chilly mornings.
                            I will replace the original (200k old) CPS and keep watch
                            Sent from my SGH-M919 using Tapatalk 2
