So I was accelerating onto the interstate last Tuesday at about 5000 rpm in 4th gear and the check engine light lit up as I was shifting into 5th. I could feel an immediate loss in power and the sound of the engine became much rougher. I pulled of at the next exit to check it out. It was running extremely rough and sounded like sputtering kinda like a blup blup blup. I had to drive it home about 2 miles. At one point I couldn't make it up a hill and had to back up twice and run the stop sign to get enough speed to make it up. I parked it but since i don't have a garage and it was dark I didn't touch it until the next morning. It had a hard time starting but finally caught. And now It will start on the first crank but then dies and wont start again. It had a rough idle before this but it never ran rough at higher rpms. Im not sure what blew but I though you guys could throw me some ideas. Otherwise Im just going to troubleshoot with my bentley.:-(
a little help?
Tags: None
Okay, you are new, so I'll go easy on you.
Break it down into smaller paragraphs.
If you have Bentley, use it before you post the question.
Put SOME description of the problem in the thread title - it will help us out.
Use the Search tool.
That is all.Current Cars2014 M235i2009 R56 Cooper S1998 M31997 M3 -
Sounds like a possible clogged catalytic to me..............
My Bro. Van did same type of thing turned to be badly clogged Cat.sigpic
Wastedincome420@yahoo.com
CURRENT STOCK LIST:
00' e38 750iL HighLine=Highway Queen
92' e30 318 vert=Aint going anywhere
91' e34 535iM=Aint going anywhere
91' e34 525iA=For parts
92' e34 535iA=For parts
