Lately I've been notacing a vibration either when I let off the gas or get on the gas in the middle of a corner. Mainly on left handers. It's a constant quick shaking like a wheel out of balance. All 4 wheels are balanced though. It does feel like it's coming from the rear of the car.
Vibration in corners?
If you think its the rear, have you checked (or ever replaced) your: trailing arm bushings, sway bar links or your rear shock mounts (go to the tech section on www.uucmotorwerks.com and there is a cheap effective upgrade for these)? Check your differential mount too.A great pleasure in life is doing what people say you cannot do- Walter Gagehot
Perhaps a passenger side front wheel bearing going?
"See, we're adding a little something to this month's sales contest. As you all know, first prize is a Cadillac Eldorado. Anyone wanna see second prize? Second prize is a set of steak knives. Third prize is you're fired."Comment
