Weird HVAC problem **evolved to electrical nightmare?
  • fatsooo
    • 312
    So my entire HVAC unit works fine...when the motor is off (key in on position)
    When the motor is running, the entire HVAC panel becomes unresponsive as if there's no power
    I checked fuse 20 and its still good
    But afterwards when I turned the motor off, it worked perfectly fine again.
    So here's a quick timeline for clarification
    Motor off - HVAC panel works
    Motor on - HVAC panel doesn't work at any speed
    Do I literally have a gremlin moving wires when the motor is running? Lol
    TIA!
    **UPDATE**
    Fuse for cig lighter and radio antenna was blown (7.5 amp when should be 30 amp) <- i don't know why this fixed the HVAC problem, but for some reason it did
    As suggested earlier (starter not being fully grounded) I ordered the heavy duty ground cable set (since my oil pan ground cable is pretty much toast as well) from a forum member and waiting for them to come in the mail so I can install those as well
    Now central locking doesn't work and something is now draining my battery
    With the fuses in and no key in the ignition, only fuse 23 is pulling 2.46V
    Checked using exposed areas on top of fuses and voltmeter
    with the fuses out, I tested where the blade plugs into the fuse box (no key in ignition again) to see how much each are pulling (where things get weird) and these are the results:
    Fuse # - Voltage reading
    4 - .22v
    5 - .22v
    6 - .22v
    12 - .22v
    19 - 11.44v
    20 - 11.44v
    21 - 11.56v
    22 - 11.56v
    23 - 11.56v
    24 - 11.56v
    25 - 11.56v <-thought this was an empty slot
    26 - 11.56v <- this one too
    27 - 11.56v
    28 - 11.56v
    I just check fuse 27 (for central locking) and the fuse is in perfect condition
    I can't even lock my driver's door so that's not really fun haha
    This makes zero sense to me as I'm a noob to electrical work so any and all help is appreciated!
    thanks again!
  • vpilarrt
    • Jun 2006
    • 2096
    It sounds like switched power is getting applied to the HVAC ground. Check pin #1 on C204 (its the rectangular 12 pin connector just to the left of the HVAC system under the dash on the driver's side). It should be ground all the time (key and motor on or off).
    • fatsooo
      • 312
      Its staying grounded. Wires are brown on both ends but I tested it too
      • vpilarrt
        • Jun 2006
        • 2096
        Now I'm wondering about the K7 unloader relay. Do your power mirrors only work with the motor off?
        • fatsooo
          • 312
          They used to work all the time. Not anymore. I'll replace the K7 relay when I'm home and update.
          • 603Racing
            • Dec 2010
            • 612
            +1 Exactly what I was thinking.
            90 325i DD/Track
            03 Durango 5.9
            Originally posted by e30mpg
            It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
            • fatsooo
              • 312
              Just swapped with a known working one, no dice.
              HVAC panel no power
              Power mirrors no power with motor running
              • vpilarrt
                • Jun 2006
                • 2096
                Check the voltages on the K7 contacts in the Fuse Panel (with K7 removed):
                86 should have +12V during start and run
                85 should have +12V during start and ground during run
                • dashboardmonkey
                  FUCK YOUR WAFFLES
                  • Jun 2008
                  • 6158
                  Sounds like an unloader issue. Problem is in the starter, replace the starter or ground the unloader wire on starter.
                  -Andy
                  • fatsooo
                    • 312
                    did this real quick before i left for work this morning, 85 was ground full time.
                    i will try this once im home from work. which one is the unloader wire?
                      I believe it is a brown wire. The black/yellow wire is the the solenoid (START) control.
                      • fatsooo
                        • 312
                        Haven't gotten the chance to do this yet.
                        If it makes a difference, which I highly doubt just throwing it out there, I disconnected the heater valve before this became an issue
                        • fatsooo
                          • 312
                          still havent done the above stated, had other pressing issues with the car so tended to those...but had a weird update tonight
                          noticed my antenna wasnt working and i needed to cigarette lighter to charge my phone. swapped the fuse (for some reason a 7.5A found its way into that spot) and now my HVAC panel works, mirrors, etc...
                          is this normal or is there some serious weird stuff going?
                          • fatsooo
                            • 312
                            Anyone? Want to finish up my heater system and its been getting nibbly lately.
                            Rather do it right the first time
                            Sent from my SCH-I535 using Tapatalk 2
                            • fatsooo
                              • 312
                              Updated first post. Is it that intense no one knows what's going on? Lol
