I have a eurospec 316i with a M40. I have an issue. The car runs fine no problems starting, but other then the normal valve train noise from the hydraulic lifters everyonce in awhile it will start to tick loudly and then if I give it some RPM's most times she will quiet down. It has absolutely no problems with anything else, and even when it does this it drives normally I am just trying to prevent further problems. the ticking usually only last 30 seconds to a few minutes, It sometimes does it abou 2 minutes after I start it and let it warm up in the morning and then it stops a few minutes later.
M40?
