Power Mirrors can only be adjust ups and downs...sometimes
  • Prost
    • Nov 2012
    • 193
    The power mirrors adjustment are occasionally work but only up and down movement, should I replace the switch as the first step?
    92 Alpine White 325iC M-Tech II Appearance Package
  • FLG
    • Sep 2011
    • 3165
    Try cleaning the connection at the door plug first.
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • Prost
      • Nov 2012
      • 193
      Got it...also, if I need a new switch, how good are those ebay used one? Should I just get a new one online instead?
        Yep, replace the switch first.
        • mikeedler
          • 6707
          the contacts in the door are probably corroded. look at them first!! it costs NOTHING. seen tons of the door jambs completely destroyed.
            The connection in the door jam only supplies power & ground to the switch. The motor control wires are between the switch and the mirror. Corrosion of the connector at switch or the motor are possibilities, but since the mirror operates in one direction the door jam connector can be ruled out as a cause.
            • mikeedler
              • 6707
              and the wires running to the pass. mirror door? wasn't posted if it was pass. or drivers mirror.
              but totally understand what your saying.
              • Prost
                • Nov 2012
                • 193
                Got an OEM mirror switch replacemant, everything works now ;)
