My 318 has leaked some oil and coolant for a while now, so im taking some time to try to fix any and all leaks. the engine was a total mess, i had to use various things to scrape the dirt off because a paper towel or rag would just smear it everywhere.
so far im going to replace:
the water pump O-ring
t-stat housing gasket
dipstick tube gasket
lower oil pan gasket
but im thinking of also replacing:
upper oil pan gasket
crank seal
oil filter housing gasket and o-ring
what should i replace?
Also, i was looking at the harmonic balancer and it looks like it might be cracked?
I also hope to get rid of the mess of hoses under the intake manifold by connecting the valve cover vent to a catch can, connecting the idle control valve directly to the nipple on the intake boot, and running a hose from here to here
I'm also installing a z3 steering rack at the moment
crank seal
