skid plate install problem
  • MoreMayhem
    • Feb 2012
    • 650
    I think I already know the answer to my question, but want to be sure.
    I searched for others who had similar install problems, but didn't turn anything up.
    I'm putting an ejnight skidplate on my m20 325i. Following the instructions, I bolted the rack to the subframe with the steering rack bolts, then proceeded to the radiator support to drill some holes.
    It seems that if I were to drill holes, they would be inside the structure, and not along the lip at the back which seems like where the holes should be. Anyone else run into this?
    I went ahead and put one hole in, and trying to get the nut inside the structure was a challenge. Tightening it was impossible.
    So I'm guessing the radiator support is bent back about 1/2" or so.
    Not sure what to do. Try to get it pulled forward? Redrill holes through the skid plate? I'm open to suggestions...
  • e30shmobberr
    • 1934
    pictures are better than words...
    Patrick - IG:niicknac
    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
    • Nick's e30
      • Mar 2012
      • 676
      I had the opposite issue, not enough to drill into. Best guess would be to fit the bolts you can.
      No antenna? I sell plugs!
      Here: https://www.r3vlimited.com/board/sho...77#post4937877
      • CHIF8008
        • 3447
        looks like the rad support has moved for you. a lot of cars front ends -end up shifting around, including the strut towers
        -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
        -The Beauty in the Tragedy-
        MECHANIC SMASH!!- (you all know you do it)
        Got Drop?? ;-)
        But of course
        E30s are know to be notoriously really really really ridiculously good looking
        • lambo
          Captain Scene Points
          • 10953
          Yupp. Had the same issue with my friends car. Ended up just bolting in the three we could and left it at that. Car is getting scrapped soon due to crazy rust...
