finding new hardware and determining pitch
  • bastianshaw
    • Jan 2007
    • 2210
    I need the specs on the exhaust manifold nuts...on both ends
    more to the point I would like to kno where I can find specs on this stuff,do I have to use calipers?
    how is the pitch of a nut determined?
  • LJ851
    • 7919
    With a pitch gauge.
    That being said, 98% of metric fasteners use a given pitch for a given diameter. For example 98% of 8mm nuts and bolts will be 8 X 1.25 , the remaining 2% will be 8X1.00 and they wont be on your car.
    With a caliper you can measure the bolt diameter and it should be obvious, an 8mm bolt will be 7.85mm or so.
    The common sizes are
    5mm x .8
    6mm x 1.00
    8mm x 1.25
    10mm x 1.5
    Lorin
    The M30 is God's engine.
    • bastianshaw
      • Jan 2007
      • 2210
      what about off sizes like 14mm? where can i look this up?
        You can look up the relevant parts on realoem.com and get the diameter and pitch. But don't use garden variety parts for the exhaust. Go to your dealer and get the copper plated self locking nuts that are supposed to be used.
        • bastianshaw
          • Jan 2007
          • 2210
          thanks fellas
