Rough Idle/ Cutting out.. Ideas?
  • bowtie2bimmer
    • 830
    I am posting this on behalf of AndrewM...
    87 325e.
    Symptoms are rough idle, ecomometer will read bad mpg. It will cut off when stopped. However the problem is intermittent. It will be fine for one drive and act up for another. Interestingly enough if I turn on the headlights the idle smooths out and everything goes back to normal...
    Any ideas?
    1987 BMW 325ic - Emma
    If by "econometer reading bad" you mean that it drives towards zero during an event, I suspect a problem with the fuel system. Run the tests in the Bentley.
    • dnguyen1963
      • Nov 2011
      • 2648
      Rough idles = vacuum leaks
      Eco meter erratic = SI board/batteries
      Turn on headlights and everything is fine = BMW electric gremlins
      • bowtie2bimmer
        • 830
        I know he has used starting fluid and checked for vacuum leaks...
        He also swapped in a different IACV...
        • dnguyen1963
          • Nov 2011
          • 2648
          Starter fluid is not a substitute for smoke test. You friend should not be doing anything else until all vacuum leaks are eliminated.
          • andrewm
            • 456
            While it might not be a substitute, the starter fluid test works pretty well. The catch is, the problem is very random and very intermittent. Not acting at all like a vacuum leak. So while it might be a vacuum leak, it's hard to get it somewhere to do a smoke test when it's unpredictable.
            As far as econometer, it reads worse mileage. Approx 50% of what it normally would be. But then, if I turn the head lights on - the econometer then acts normally almost every time.
            1987 Delphin 325e Sedan - Natalie
            1990 325i 24v
            1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
            • dnguyen1963
              • Nov 2011
              • 2648
              That is precisely the problem with vacuum leaks...intermittent. Many of the connections are old and seem to be tight visually, but when the car is moving these connections can become loose and create vacuum leaks. Smoke test under pressure will normally find these leakages.
              As for the econometer, are you talking about the actual gauge or the reading from panel?
              • andrewm
                • 456
                The acual gauge on the cluster.
                1990 325i 24v
                • dnguyen1963
                  • Nov 2011
                  • 2648
                  You might have to remove the cluster and exam the board under a magnifying glass for any cracks in solder. Clean all contacts and tighten up the ground nuts.
                  • andrewm
                    • 456
                    well, the events are related. I highly doubt there's an issue with the SI board. the hesitation, and econometer work hand in hand. When I turn the lights on, most of the time it fixes both of the issues. See where I'm going with this?
                    1990 325i 24v
                    • andrewm
                      • 456
                      So, an update, it stalled on me again. I couldnt get it to start, so i unplugged the maf. Started right up, but i couldnt give it any gas or it would die. If i plugged it back in, the car died. Thoughts?
                      1990 325i 24v
                      • dnguyen1963
                        • Nov 2011
                        • 2648
                        Your fuel/air ratio is messed up. I still think that you have some massive vacuum leaks. It is time to do a smoke test. I do not know why turning on the headlights fixes your issue though.
                        • andrewm
                          • 456
                          Yea, I'm gonna try to get a smoke test done this weekend. My work schedule makes it impossible during the week. That and the fact I rarely drive the e30
                          1990 325i 24v
                            That increases the load on the engine and the DME would respond by opening ICV further to increase mass flow. That in turn would increase the amount of metered air in comparison the un-metered air from the leaks.
                            • EH Motorsports
                              • Jan 2013
                              • 19
                              Actually the dme will see a voltage change and increase injector duty cycle to compensate for the added load. Thus making a lean running condition better due to more fuel.
                              https://www.facebook.com/ehmotorsports
