leaking fuiled
  • timmytwotimes
    • Aug 2012
    • 29
    leaking fuiled
    I was driving today and all of a sudden my car started smoking inside and I have radiator fuiled on floor? What is that? And leaking outside the car of course, I haven't even looked at it yet just cause its dark, I'm going to take a look tomorrow, but I just wanted to see if anyone could save me some trouble and tell me what it is
  • roguetoaster
    Biggus Tippus
    • 7830
    Probably a coolant line failed and spilled coolant onto a hot engine component. You should be able to spot the trouble quickly by filling the coolant back up and starting it to look for leaks. Hope the engine didn't overheat in the process.
    • dnguyen1963
      • Nov 2011
      • 2651
      Most likely, your heater core is busted.
      • ethirtydavid
        • Jan 2008
        • 2331
        Yeah, coolant in the car seems like heater core- but if it's outside also maybe its an engine bay hose and is dripping inside the cab.
        Dry off and clean up the area, start your car and check for where the leak originates
        • SmokeE30
          • 1730
          There is a tube to direct fluid leaking from the heater core In case of a lake to under the trans tunnel I forget the name of it but the only coolant that enters the cabin of the at is in the heater core so that is probably gonna be what you find has failed
          Shawn @ Bimmerbuddies
          Bimmerbuddies LLC
          717-388-1256
          2971a Roundtop Rd, Middletown PA 17057
          bimmerbuddiesllc@gmail.com
