Why my fuel pump is loud??
  • amcink
    • 788
    My fuel pump after the car is driven by few miles it starts to whine loud. What is going on?
  • IAmGary
    • Apr 2012
    • 183
    It's dying. Sometimes they die silently but any sound is a sure indicator that parts are failing. The poor thing has been pumping for decades! I just replaced mine today, it's a 20 minute job. Here's my blog post, here's the how to. Good luck!
    • e30m20TurbO7
      • 1203
      What he said , buy a 255 walbro
      • 2761377
        • Jan 2011
        • 398
        if the filter is as old as the pump, replace it first
        • SmokeE30
          • 1730
          My fuel pump has been loud for as long as I've had my car, I guess it's probably just a aftermarket one because it's been pumping fine for a year. The fuel pump I put in my truck after the original failed was a aftermarket unit(autozone special) that although flows a lot more I think is just louder because it's not oem
          Shawn @ Bimmerbuddies
          Bimmerbuddies LLC
          717-388-1256
          2971a Roundtop Rd, Middletown PA 17057
          bimmerbuddiesllc@gmail.com
            A whining pump is one that is working too hard or that is badly worn. A clogged fuel filter or a rusty fuel tank will cause the pump to have to work too hard. If the tank is rusty that rust will collect on the inlet screen while pump is running and choke off flow. Once the car is parked for a the rust will fall off and settle out, until the next time the car is driven. Rust is highly abrasive and will wear the pump (and clog the filter pretty quickly).
            • Andy348
              • Sep 2009
              • 688
              Check the tank for rust before anything else (other than filter change). I changed two pumps just to find out that the rust in the tank was killed them both.
              • IAmGary
                • Apr 2012
                • 183
                That advice on rust is good, never heard that before.
                • amcink
                  • 788
                  I have two pumps and this is the pump on the outside below the rear driver side. Also the fuel filter is new. So i guess is dying
                  • Chuck C
                    • 104
                    Your intank pump is dead, which makes the main pump work that much harder.
                    • amcink
                      • 788
                      Thanks! I'll check the intank pump
