Why does my car run like hairy asshole
  • BahnE30
    • 1050
    go out first thing is the morning, car is stone cold.... starts fine idles fine, give it some gas and it misses like it's it's job..... once it's warmed up it runs like a champ now if you start driving it right away it'll go away about 1km down the road, it only does this when ambient temp is cold like -10c or if it's rainy..... plugs and wires do the trick?
  • SpecM
    • Oct 2005
    • 4531
    -Ehhhh... mine does the same. Runs stupid until I drive about 3 min.
    1989 cirrisblau-metallic 325i
    • Drewe30e
      • Apr 2005
      • 171
      I had a problem similar to this a couple years ago. I replaced the plugs and it ran great after that. I would replace the plugs first because they're cheap, and if that doesn't do it, look into other tuneup possibilities (wires, rotor, distributor cap, etc.).
      1985 325e - 5000 RPM's of Fury
      • kowalski
        • Jan 2005
        • 1791
        you can visualy inspect most of those things, if you dont know when the last time they have been done, then chances are you have to do them.
        • BahnE30
          • 1050
          as i suspected, but we all know it's easier to type then to go out and actually look. lol
          • 65Matt
            • 172
            temp sensor.
            • zandi
              • Apr 2004
              • 602
              how does a hairy asshole run like?
              • 318isbmw
                • Nov 2005
                • 2843
                dunno, but my guess is that it depends on what you ate
