Gas Leak Smell
  • JinormusJ
    • 6887
    Gas Leak Smell
    Problem:
    Gas smell in cabin after e30 sits for long period of time
    Status:
    Wasnt bad at first, but is now officially annoying
    Known factors:
    1989 325is
    Stock m20
    Only smells after sitting, not while driving
    Smell comes from engine bay primarily (running rich?)
    What can be causing it? I'm going to lift out the back seat an check my filter gaskets and everything soon to eliminate possible problem areas. Anyone got any clue on where to even start..?
  • CHIF8008
    • 3447
    if it smells when sitting i would say that the fuel is de-pressurizes itself from the system because you may have a leak with one of the hoses. id just do a visual check of all the fuel hoses in the bay while its running. fuel rail attachments ect...
    my car always seemed to smell of gas when i would stop after i was driving. figured out that i smelled gas because my "security door" in my gas fill tube was broken off from someone stealing my gas. thus the fuel vapors leaked out from the vent pipe. my fiancee's e30 leaked at the back of the fuel rail. just a small tighetning up on the hose clamp and it fixed the problem
    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
    -The Beauty in the Tragedy-
    MECHANIC SMASH!!- (you all know you do it)
    Got Drop?? ;-)
    But of course
    E30s are know to be notoriously really really really ridiculously good looking
    • ELVA164
      • 4861
      If you're sure it's from the engine bay then disregard this, but the fuel hoses just above the level sender under the rear seat are known to decay and can leak. You can see them here:
      • JinormusJ
        • 6887
        Thanks for the input guys
        I'll check all the potential problem areas and start eliminating factors as I check them. I'll probably start in the back at the fuel level sender cause I've heard that one more often and then work my way forward
        • dnguyen1963
          • Nov 2011
          • 2649
          Replace all your fuel hoses. They have been known to have many micro-cracks after some 20+ yrs on the road.
          • JinormusJ
            • 6887
            Checked fuel filter area; did not see leaks, but there seemed to have been moisture buildup on and around the gas tank/foam on the fuel level cap (the one that goes over the hole).
            The paint on the gas tank has also seemed to have been peeling, possibly because of the gas leak?
            The engine seems fine, but I can still smell the faint puffs of fumes from the engine as well, and after allowing to sit after running, there is a buildup of fumes in the bay
            • ELVA164
              • 4861
              Yes. Also, pay attention to the seal around the level sender/pump unit itself, because that may not be completely sealing. As far as the smell in the engine bay, I agree with everyone else: replace everything because it's more than likely dry and cracked.
