Is this a bad sign??!
  • Nick_S
    • Apr 2011
    • 3655
    So I started tearing into my car for some refreshing for the spring. Some new gaskets, new paint and cleaning up the engine bay etc. When I pulled my intake elbow off, there was a good bit of sludgey looking buildup inside the elbow and on the throttle body....
    Pulled the crankcase breather off, same looking crap in there...
    I had some similar stuff on my oil cap last year and my friend who's a mechanic told me it can be normal and from condensation. I'm worried it's a sign my head gasket is leaking. I pulled the valve cover off and everything is very clean under there and was surprised to see the timing chain and gears in very good condition still. Last time I changed my oil it wasn't discolored or appeared to have coolant in it. I need to empty my pan and do check it tomorrow.
    So R3V I'm asking you. Does it look like I've got a problem on my hands or is this fairly normal?? I've never had a potential head gasket problem, what's the best way to test for this? I know this is an M42 but that sub forum doesn't get as much traffic.
    Thanks
    Nick
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
    That is rather common in cooler weather and doesn't necessarily indicate a problem. What it means is that the car isn' driven long enough under load to get the engine host enough to boil off condensates. A couple of trips a week with 30 minutes of sustained highway speed driving will make a big difference.
    • Nick_S
      • Apr 2011
      • 3655
      That would make sense seeing as I don't drive it much at all in the winter.
      05 Honda Pilot
      24V swap thread
      • ak-
        • 12422
        J sauce is right. I have the same condensation crud in my breather hose/catch can lines, especially when it's cold out.
        1991 325iS turbo
        • Nick_S
          • Apr 2011
          • 3655
          Thanks guys. Got pretty freaked out there for a few. Don't have the money for a full rebuild right now :up:
          05 Honda Pilot
          24V swap thread
