eta performance
  • Bav///Motorworks
    • Nov 2005
    • 98
    eta performance
    ight just got the chip in and must say wow... huge difference
    but i want more!!! i just want more up top.
    i would like to kno, the I intake manifold and throttle body will help? and what about a I exhaust manifold and back? anything to let this motor wih the chip breath better. thanks
    i kinda wanna add another 20hp if its possible without doing any major mods such as p&p the heads and etc.
    88 325is (a work in progress)
    new/old black interior
    bilstien + eibachs
    IE billet aluminum rear strut mount with urethane bushings
    custom exhaust with flowmaster
    cone filter with heat shield
    z3 shifter
    eclipse reciever with mb quarts components
    e28 mtech 1 spoiler
    87 535is
    custom exhaust with cheapo muffler (PO)
    bilstien w. stock springs
    bavauto 8mm plug wires
  • X2theZ3
    • Mar 2004
    • 932
    20 more hp will be very hard. do major mods if you want power. Stroker.
    • James Crivellone
      Head Janitor
      • 6304
      When I had an ETA motor in my car, I had the following which put quite a few smilies on my face.
      M20B27
      Jim C Chip
      I Intake Manifold
      I Throttle Body
      I Exhaust + Manifolds
      3.25LSD out of a 535is.
      It was a very fun car, 2nd and 3rd had a decent grunt, however the lack of top end that the eta motor has didn't help..Needless to say compared to the original configuration it helped a TON.
      I now have an M20B25, Mark D, 13.5LB Fly (I would do this on the eta as well, would help), No AC, and a 4.10LSD and the difference is amazing...
      You could also look into not so popular options, such as a 323i 731 Head, which helps the motor out a good amount, or Turbo, or some have even done an I Cam with I valvesprings (requires some machine work on the head) as well with I Motronic and that has really opened the motor up.
      However for around the price of getting all those parts you can find a used I motor as well with decent mileage...
      My
      • Jon '92 325ic
        • 172
        For more power up top
        As was already suggested, switch to the I intake manifold, plus have it Extrude Honed. Your performance above 3,500 rpm will be noticeably better. You can get a used i head with throttle body for $25 - $50 on eBay. Having it Extrude Honed I think goes for $600 - $650 nowadays.
        A 4.10 rear diff will also improve performance (acceleration, not HP or torque), but more so on the low end. You'll be noticeably quicker off the line and will get to higher rpm quicker. Using a 10-speed bicycle as an analogy, a 4.10 rear diff would be like taking off from a dead stop and racing to top speed in 9th gear whereas a 3.73 rear diff would be like being in 10th gear. Eventually, the rider in 10th gear will catch up to the guy in 9th gear (while pedalling less) and reach a higher maximum speed, but the guy in 9th gear (4.10 rear diff) will be quicker off the line and will reach his maximum speed first. You'll give up a little fuel economy going to a 4.10. You can get a good used open 4.10 on eBay for $75 and up. Joel at EuroDepot sells used open 4.10 diffs for $150 I believe. His have been sandblasted and repainted and I believe a new mounting bushing is installed also. A used limited slip 4.10 go for $300 - $450.
        • James Crivellone
          Head Janitor
          • 6304
          Jon this is an ETA we are talking about here, with a stock redline of 4800, and a chipped of 5200, he will have ZERO topend with a 4.10, let alone a 3.73.
          a 3.46 is even pushing it.
          Considering stock ETA's made after 04/86 had a 2.93 Gearing in them, a 3.25 is a nice upgrade to give it a little more oomph, especially if he has an 84/85 which came with 2.7X Geared diffs.
          • Bav///Motorworks
            • Nov 2005
            • 98
            do u really notice the difference with the I intake manifold/throttle body and exhaust/manifold? i can pick those up...
            bilstien + eibachs
            z3 shifter
            e28 mtech 1 spoiler
            87 535is
            • Bav///Motorworks
              • Nov 2005
              • 98
              i have an 86 which has the 2.93's.... where can i find the 3.25 off teh 5 series... i don't go on 5 series boards
              edit: aslo i would like upgraded cams if there any available. i luv the rough idle and etc and of course the gains
              bilstien + eibachs
              z3 shifter
              e28 mtech 1 spoiler
              87 535is
              • Jon '92 325ic
                • 172
                Thanks James
                Didn't know Es came with 2.93 rear diffs. So James is correct, going to a 4.10 is not recommended. Like James suggests, if you have a 2.93, going to a 3.25 would be the way to go. Don't even think about going to 4.10 from a 2.93.
                Thanks James.
                • formula driver
                  • 2263
                  I have an I intake manifold and throttle body that I will sell. The intake manifold is painted with sanded ribs. PM if your intrested. Ill give you a great deal.
