The above title. Recently, I pulled the TB to replace the TPS. When I put it back on, I developed a coolant leak from the TB heater. I decided to bypass it, and things were fine. Yesterday, my car was running hot and steam was coming out of the hood. I opened it up and it was leaking from the fitting. Tightened the hose clamps and the leaking stopped. I
Didn't get to top off the coolant until today, and even when I did, it was still running hot, and the coolant turned a bit gray. Help?
Side notes: I think it could possibly be the fitting, as it may not be large enough. Also, I seem to have lost a blade sometime recently on the radiator fan, but I wouldn't think one blade would make it run nearly in the red.
Sorry about the formatting, I'm on my phone at work.
Sent from my PG86100 using Tapatalk 2
