87 325is cluster question
    Hey guys with my new e30 purchase it seems to be missing its cluster. We know its around 200k. Anyways I hit the local pick n pull yard and got an 88 325is cluster. I also pulled an 87 cluster but it was in a convertable and was rusted inside. However I was able to pull the fuel gauge since I had herd 87 gas gauge read different than an 88. Anyways I hid the rest of the cluster in another car in case I needed other parts from it. So my question is can I just run the 88 325is cluster or do I need to swap the fuel gauge from the 87 into the 88? Secondary question do I need anything else from 87 cluster?
    Thanks in advance.
    1987 325is- $700 project car
    1996 Pontiac Firebird Formula - Bolt ons,cam, 6 speed of fun.
    2001 Miata - Current DD and to be for sale soon.
    The Build- http://www.r3vlimited.com/board/showthread.php?t=281011
    Parts Car Part Out Left Overs- http://www.r3vlimited.com/board/show...21#post3860521
    What car do you have?
    If a 325 that was built before 9/87, it will have the 53L fuel tank and will need the early (up to 8/87) fuel gauge.
      I have an 87 325is. I guess I will have to check the date code on the door then.
