Fuel/Exhaust Smell in Cabin
  • FasterSoonerNow
    • Jan 2013
    • 66
    I've had this fuel smell in the cabin since I got the car last month and it might be getting worse. The smell isn't quite a raw fuel smell, more of what I'd expect if a car was running rich. It's not coming in from the exhaust because having my window open helps and yesterday I put my nose right up to the exhaust and I could barely smell anything (plus it just passed PA emissions), but then I went back in the cabin and I could smell it instantly. I'm starting to wonder if I have a leak and I am just not realizing that it is raw fuel. The lines run by the driver side, correct?
    Check all of the hoses in the engine bay for leaks and check under the access cover(s) under the rear seat.
    • FasterSoonerNow
      • Jan 2013
      • 66
      Is there a good diy on this? I have the bentley so I'll pull that out this weekend.
      • dnguyen1963
        • Nov 2011
        • 2649
        You don't need a diy for this. Just replace all of your fuel hoses. For the rear seat, just pull it straight up then a few screws to remove the covers. Check for leakage there.
        • FasterSoonerNow
          • Jan 2013
          • 66
          Will do. What would the smell be like from a leaky valve cover? I'm still thinking it might be something other then a fuel leak cause it has a mix of gas and oil. Sort of similar to running a lawn mower.
          • oldmann
            • 265
            You may be getting the engine bay smell through the rubber grommet that goes around the steering shaft, where the shaft passes through the firewall.
            • FasterSoonerNow
              • Jan 2013
              • 66
              That might make sense. I have my driver side kick panel off because I did an of odometer fix last weekend. Might be why I noticed it was stronger yesterday.
