Possible moisture in fuel tank issue? UPDATE: Now with video!
  • Pocket Chant
    • Mar 2012
    • 403
    Alright, so first of all, I derped. I happened to leave my gas cap open throughout the rain that was supposed to be snow. I left the cap on the door, and the door shut, so I didn't notice it was open for a while. I fixed it and it was fine. Later, though, I was driving and lost power from the engine. It seemed like it wasn't getting enough fuel, and I had to keep it at 3k+ or it would nearly stall out, occasionally backfiring. It'd last for a little while, then clear up and be perfectly fine.
    This was three days ago. Yesterday and today though, when I first started the car, it ran fine without any problems. After I drove it, then parked for a bit, the problem would resurface. I think it's moisture in the gas tank, but I'm not sure. Should I just put Heet in it or could it be something else?
    EDIT: Here's a video of the situation. This seems to only happen after I've started it up before.
    And a link, since embedding is iffy.
    1987 325is, S50B30US, Kamei side skirts, Zender Spoiler.
    MT2 Wheel, 95 M3 Rack, Condor Speed Shop knob, UUC SSK w/ DSSR, Billy Sports/GE Coilovers, KAMotors CAI.
    Originally posted by MclubSport
    Why you have a badge on wheel ? You do not know what car you have? But if you have a mustache, you know better where is your mouth?
    Horrible with responding to PMs, I'm so sorry.
  • dnguyen1963
    • Nov 2011
    • 2648
    Put Heet in the gas tank. Water is heavier than gasoline and sinks down to the bottom of the tank where the pump inlet is located. You must have a shit-load of water in your tank. If Heet does not help then draining and drying (stick a hose with compressed air for about 20 min) the tank would be an option then re-fill with fresh gas.
    • akonsing
      • Mar 2013
      • 1
      i think you should heat it a bit. it will evaporate what ever is causing the problem.
      Rajasthan Tour India Car Loan Manali Tour Packages
      • dnguyen1963
        • Nov 2011
        • 2648
        Heat and gas vapor is not a good combination. Highly recommend against doing this.
        • Pocket Chant
          • Mar 2012
          • 403
          Yeah, no. Not doing this. Video added to the main post.
            That is not moisture in the fuel supply, but rather some sort of engine management problem. The first action would be a smoke test.
            • Pocket Chant
              • Mar 2012
              • 403
              Well that's slightly relieving, I think...
              What I'm not sure is portrayed accurately in the video is that it'll bog completely regardless of how open the throttle is, and I have to pump the throttle to get the revs moving again. I'm going to check all my connections and see how that goes.
                I found that apparent in the video, which is one of the reasons I said it was an engine management problem.
                • Pocket Chant
                  • Mar 2012
                  • 403
                  So, pulled the battery for a bit, seemed to fix about 90% of the issue. No more bogging or stalling, but the engine is running a bit rough still. I may try it again, because I let the car idle instead of driving it immediately after
                  Sent from my PG86100 using Tapatalk 2
                  • Pocket Chant
                    • Mar 2012
                    • 403
                    So it eventually ran smooth, whatever. It was fine until I ran it through a car wash (touchless), when the problem resurfaced. I played around with the battery cables and it went away, so I think it might be an issue with corrosion? The terminals look fine, but I couldn't get the negative cable off the battery at all. I'm going to have a look at it when I have some free time, but that won't be for a few days. I'll update with what I find.
                    • Pocket Chant
                      • Mar 2012
                      • 403
                      So, problem came back. I'm pretty stumped, too, this time not even pulling the battery worked. I still have good voltage and all, could it be a fuel issue?
                      • dnguyen1963
                        • Nov 2011
                        • 2648
                        If the problem resurfaced afte you have gone through a car wash then I would concentrate on electrical problems. Go through the car carefully and examine all grounds.
                        • jclar
                          • 265
                          This. And I wouldn't rule out intake leaks at this point too, as mentioned earlier. Check your grounds, and clean them up if you haven't already done so.
                          '86 325es M50
                          • Pocket Chant
                            • Mar 2012
                            • 403
                            Uhh.
                            So I finally had time to check the condition of the grounds during lunch and... well, I couldn't find it.
                            I did find this random eyelet though, is this where the ground cable should be?
                            If I don't have a ground, I'm not sure what to do, as this was a recent occurance. I ordered new cables though, so they'll be delt with anyway.
                            • dnguyen1963
                              • Nov 2011
                              • 2648
                              Bentley manual shows all the ground points.
                              Table t. Wiring Harness Ground locations
                              Ground point Location
                              G1 00 In luggage compartment, behind battery (6-cylinder models
                              with trunk-mounted battery)
                              In engine compartment on right shock tower (all models with engine compartment-mounted battery)
                              G1 02 On top rear of engine (4-cyl inder engine only)
                              G1 03 On right front shock tower (2.5i engine only)
                              On left side of engine block, above starter
                              (2.7e engine only)
                              G1 04 On front fender, behind left headlights
                              G200 Beneath instrument panel, above brake pedal
                              G201 On steering col umn, near horn brush/sl ip ring
                              G300 Beneath left side of rear seat bottom
                              G301 In luggage compartment
                              G600 In windshield header
