Tranny fluid DIY?
  • CrJdMc
    • Feb 2012
    • 195
    Tranny fluid DIY?
    Sup guys, I have an 87is, and I recently bought 2 quarts or redline MTL 90 because I figured my tranny is in need of some new fluid, anyway, I was wandering if there is any diy's for this or if anyone can walk me through this, i know it can't be that bad, thanks!
    sigpicInstagram: bir_madhatter
    Add me on Facebook: https://www.facebook.com/connor.mcco...57?ref=tn_tnmn
    Pretty simple really. The car has to be up in the air and level. You don't want to drain the transmission and then find that you can't get the fill plug out, so remove the fill plug first. Then remove the drain plug and drain the fluid. You will have to have a pump of some sort to put the fluid in. Fill the transmission until fluid comes out of the fill opening.
    • Vivek
      attention whore/retard/bitch
      • 6167
      Sorry for the OT, but I filled mine with the passenger side jacked up, so I may have slightly overfilled it. Could that cause the tranny to leak, because I swear mine started leaking like a bitch after that.
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • ELVA164
        • 4861
        I didn't have a pump when I did mine, so I ran a length of hose down from the engine bay to the fill hole and put a small funnel at the top. Obviously you need to remember that the hose is full of fluid when you're filling, but it worked great other than that.
        • dnguyen1963
          • Nov 2011
          • 2651
          Here you go...took me 2 sec with Google search.
          Change your E30 transmission fluid the easy, cheap way: the 17mm hex trick, fluid choice and fill/drain plug tips.
          • CrJdMc
            • Feb 2012
            • 195
            Thanks guys!
            • ELVA164
              • 4861
              Yikes, I definitely prefer filling the funnel outside the interior...
              • dnguyen1963
                • Nov 2011
                • 2651
                Personally, I just use a 60 mL syringe to fill the trans.
                • Swanny
                  • Mar 2012
                  • 2834
                  Oh great idea! I had a small syringe type doohicky that I used last time. Frustrating and messy. Will keep your method in mind for next time.
                  Swanny!
                  SUCKERS.
                  • noid
                    • 1537
                    Why? I don't see anyway you could make a mess, unless you spilled while pouring?
                    Once you are done filling, you detach the funnel (with a bounty towel or similar at the tip), and then you pull the tube through the bottom. You would have to be a complete noob to even spill a drop.
                    Going through the engine bay requires more tubing, and more fluid waste when you pull that tube out of the fill hole hole.
                    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                    Your resource to tools and tips: www.rtstools.com
                    • Swanny
                      • Mar 2012
                      • 2834
                      More tubing sure, but just account for the fluid being in the tube while you pour. Much safer And less annoying than tearing up that damned annoying rubber boot.
                      Swanny!
                      SUCKERS.
                      • dnguyen1963
                        • Nov 2011
                        • 2651
                        What! the rubber boot can be pulled off easily. I don't see how it can be annoying...
                        • ELVA164
                          • 4861
                          I dunno, I'd just prefer the extra hose for the peace of mind. Works fine the other way, I just wouldn't be as relaxed about it.
                          • noid
                            • 1537
                            The rubber boot couldn't be easier to pull to the side. It is extremely elastic, and the only way it would tear would be if it was old and brittle, in that case it needs to be changed anyways.
                            • Swanny
                              • Mar 2012
                              • 2834
                              But this is r3v.
                              Swanny!
                              SUCKERS.
