That little darn throttle body passage is leaking. I snapped one of the 3 small bolts holding it in place. I did not want to render the car useless. So, I am planning on either removing the throttle body or bypassing it. Does anybody have directions on how to bypass it and also, will the throttle body come off fairly easy or is that usually a problem?
I think I will need a TB gasket. Would I need anything else?
Directions on how to bypass? On edit - Do I just connect the two small hoses? Is that larger center hose just a vacuum hose? So I could leave the center attached and connect the two small ones?
Thanks.
Thanks.
