wtf is this noise(suspension)
  • NC325iC
    • Mar 2004
    • 6565
    ok for quite some time now i have had a loud clunking noise in my right front suspension. at fist i thought it was the strut moving inside the tube, but the collar seems to be tight. then i thought mybe the CABs, nope. what else should i check. could it be a bad balljoint? sounds like a loose somthing is bouncing around with every bump. very annoying. ive looked around to see if anything has been getting damaged and i havent spotted anything. any help would be great.
  • permit
    • Mar 2005
    • 3363
    Someone a while back claimed it could be the steering u-joint. I have the same noise, and it's only at slow speeds.
    • madjurgen
      • May 2005
      • 1203
      But you should have a lot of play in the steering wheel if thats the problem.
      As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
      You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
      • permit
        • Mar 2005
        • 3363
        Which I do. Therefore, I picked up a new u-joint. I'll report when I get it in if it was the reason for the clunking sounds.
        • NC325iC
          • Mar 2004
          • 6565
          yes but the steering linkage is on the left side and my noise comes from the right. no excessive play in the steering. happens at all speeds
          • RobertK
            Kicked cancer's ASS.
            • Jun 2005
            • 5864
            Sounds like the same problem I have when my control arm ball joint took a shit. Jack your car up and pull on each wheel and shake on it a bit. If the ball joint is bad it should move around. If the ball joints are good nothing should move.
            • kowalski
              • Jan 2005
              • 1791
              its your shock mounts.
              • AdamF 88iS
                • 2051
                Not in the front it isn't.
                Check the ball joints and sway bar mountings. If the sway bar broke the mount off of the subframe it makes some god awful clunking. Bad ball joints usually arent that loud unless they are waayy gone.
                Adam Fogg- '88 M3
                Common sense- It's the new 'gifted'
                • marakka
                  Euro Parts Pimp
                  • Apr 2005
                  • 2036
                  Had this noise when I picked up the touring. EVERY bump no matter how small caused a rattle to a smashing sound coming from the right front. I only drove it from my post to the shop. Had the suspension changed out for RD and Bilstein. Turned out the right front spring had broken and was missing a coil.... I doubt thats what this is but it could be.
                  As stated above, jack the car up and with the tire on grab the tire at the 12 oclock and 6 oclock positions and shake up and down. If there's ANY play whatsoever you've got a bad ball joint. Check the sway bar mounts like the feller said above..... that'll get you TONS of noise also.
                  • NC325iC
                    • Mar 2004
                    • 6565
                    highly doubt the spring is broken its about 2 years old. ive got new balljoints on the way. well see if that helps any, hopefully it will, if i can scrounge up some more cash i mgith get some ST sways on there which come with mounts and stuff so well see how that goes.
                    thanks for the help
                    Chris
                    • Jordan
                      • 12916
                      I love morons that buy new parts on a whim, rather then actually checking to see if they need them.
                      https://mtechniqueabs.com/
                      • 808BMW
                        • 2910
                        One time my swaybar bushing took a shit and crumbled away, Thus making my swaybar bounce around inside the whole bushing housing area, making lots and lots of noise.
                        • NC325iC
                          • Mar 2004
                          • 6565
                          well jordan i have been told more than once that it may be ball joints and if its not oh well theyre 17 years old anyway they should be replaced. as for the sways they would be an upgrade over stock even if they dont fix the problem. why dont you think about it just a little more before you open your mouth for another useless comment
                          • T.Dot E30
                            • Mar 2004
                            • 536
                            It could also have been the inner or outer tie rods, you should have jus get it checked out instead of buying random parts.
                            • NC325iC
                              • Mar 2004
                              • 6565
                              yeah probably, well see
