cooling system worries. with some data
  • dnguyen1963
    • Nov 2011
    • 2651
    #31
    You already measured the temps and they were fine coming out of the t-stat housing (180F = 82 C). I assumed that you have a working 80C t-stat. The top of your rad should stays close to 80C then cool off significantly at the bottom of the rad. Your reading for the upper rad is a bit high (210F = 98C) so either your fan clutch is getting weak or your rad is clogging up.
    • Chriskbmx
      • Apr 2012
      • 972
      #32
      ok is there a sure fire way to check for a rad clog? and i have another clutch fan i will install!
      • dnguyen1963
        • Nov 2011
        • 2651
        #33
        How old is your rad? If it is 20+ yrs old then just replace it. It is not worth the trouble trying to flush an old rad.
        • Chriskbmx
          • Apr 2012
          • 972
          #34
          im a broke college kid, it is not really in my budget to buy a brandnew rad.
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            #35
            If you can't maintain the car, you should be driving a Civic.
            • dnguyen1963
              • Nov 2011
              • 2651
              #36
              Ok, you can take your rad out, pour in 10% bleach and let it soak overnight. Flush the rad out in reverse with water until you do not smell bleach anymore. Hopefully, that will buy you a few more years. Check the rad fins to see if it is still in good shape. If it is flaking off then I am afraid that you have no choice but to save money and buy a new one.
              • Chriskbmx
                • Apr 2012
                • 972
                #37
                I can afford an e30. I actually am broke momentarily because I just bought another. And thank you I will try that!
