What to change with engine/trans out
  • PeaveyBassist
    • Sep 2004
    • 3511
    I will be swapping engines as most of you know. I need a list of all I want to change on the car while the engine is out. Here is my list so far.
    Front/Rear main seals
    Front/Rear cam seals
    timing belt
    water pump
    oil pump
    oil pickup
    oil pan gasket
    head gasket
    head bolts
    all rubber hoses on engine
    accessory belts (getting rid of AC I think)
    thermostat
    dist. coil
    dist. cap
    dist. rotor
    clutch kit
    clutch fork
    tranny seals
    all shifter bushings
    flexdisc
    center support bearing
    What else? :)
    Will
    ADD: Motor mounts
    Transmission mounts
    Of course along with clutch... Pressure plate, throwout bearing, etc.
    23mm Brake Master cylinder (ala e30 m3) and the line needed to connect it
    Clutch master cylinder
    Clutch slave cylinder
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
  • Dave
    E30 RAT
    • 11675
    motor mounts
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • PeaveyBassist
      • Sep 2004
      • 3511
      Oh yea, forgot to add those on there. motor mounts and tranny mounts. Ill add em. Thanks Dave.
      Will
      DaveCN = Old Man
      • James Crivellone
        Head Janitor
        • 6305
        Fuel Filter
        Master and Slave clutch cylinders if they are original (always a good idea imho)
        Fuel lines you listed.
        Any suspension stuff on the front end.
        Any wiring alterations.
        Heater Blower motor (check it)
        • ColdAccord
          • 5926
          you think its necessary to change the oil pump? if i remember correctly they're like $150-200
          Originally posted by blunt
          • PeaveyBassist
            • Sep 2004
            • 3511
            control arms and control arm bushings were replaced 20-25k ago, as were tie rods. Should I go ahead and change the control arms just because the inner ball joint on the CA's are hard to get to?
            Will
            DaveCN = Old Man
            • PeaveyBassist
              • Sep 2004
              • 3511
              I get parts cheap from the dealer. Plus, I have to change the pickup, oil pan and gasket anyways so why not? I'm getting the engine from an iX so thats why I need to change the oil pan and pickup.
              Will
              DaveCN = Old Man
              • Hatchman
                • Mar 2005
                • 1425
                Will
                is this like a part's ix? does it have a drivetrain in there or tranny?
                • PeaveyBassist
                  • Sep 2004
                  • 3511
                  Its a parts ix as far as I know. PM me what you need and I will see if the guy has it... if so... maybe we can work somethin out ;)
                  Will
                  DaveCN = Old Man
                  • kansas-ix
                    • Jan 2004
                    • 1600
                    What do you need I have it, ALL + some more.
                    BTW it is close to official I'm going to Part my IX if some buys something that makes it worth while,
                    BTW again your list looks like your car will run for another 200k if you change all that.
                    E30 325ix 62k
