Within next year, a great deal of time will be spent under 318.. full (front and rear) suspension refurbish: all bushings, Bilstein sports, shorter springs, motor & trans mounts, trans seals, skid plate, short throw/shift linkage rebuild, LSD swap, exhaust, guibo, center bearing, etc..
I have 4 jack stands and 2 floor/shop jacks. (one full size – one smaller)
(Also have a set of ramps but expect front lip clearance will/would be a concern.. in addition to obvious lack of usefulness regarding suspension disassembly/re-assembly.)
During past maintenance, it seemed like jack clearance was tight, and expect it to get tighter with lowered suspension.
As of now, expecting/planning to use chunks of 2 x 6 lumber under tires to raise car up and help gain clearance for floor jacks.
I’m familiar with proper jacking points.. mostly fishing for ways make things easier clearance-wise.
Any tricks/tips/suggestions appreciated.
