most cost effective swap?
  • chop_suey
    • Nov 2009
    • 270
    M20 2.7 turbo vs. M30 vs. M5x vs. M60 vs. LS1
    Which setup do you think is the most cost effective way to go as far as the amount of power output and reliablity goes?
    Or if you have a better one tell us.
    85 325e 5spd
  • travish325
    • Jun 2012
    • 1151
    m30 extremely reliable-not to much extra power over an m20
    LS1 not as reliable as m20/m30-way more power and not very expensive, cheap upgrades
    m5x reliable- not a whole lot of power in stock form
    m60 pricey to build but reliable, good power and still a bmw engine (if that matters to you)
    Honestly I would do an s50 swap. Theres lots of possibilities for performance and its very reliable, Plus I like staying straight 6 in e30s when it comes to swaps.
    • unevolved
      • Nov 2011
      • 714
      Honeywell AGT1500.
      1991 318i SOLD
      2003 325i SOLD
      Racecars and stuff.
      • chop_suey
        • Nov 2009
        • 270
        Anyone else
        85 325e 5spd
        • Exodus_2pt0
          • 5943
          Ls1 is very expensive if you want a manual. For an aluminum block your looking at around 2k, then another 1.5 to 2k for a good t56. Biggest cost is the trans because it can be mated to many engines with conversion bell housings, so they are getting to be slim picking.
          It's not on your list, but I am currently up to only $200 into my 5.0/t5 swap and the car is nearly finished. Granted I traded labor for the drivetrain, but that can be had cheap. Great power with a good set of heads and cam, plus reliable if you keep it reasonable.
          No E30 Club
          • TheTacoMan
            • Nov 2011
            • 2308
            All of those engines can be reliable with the right set up that said, most reliable for the $/hp is probably the s50. Just my 2 cents.
            • Nick_S
              • Apr 2011
              • 3655
              I was toying with the idea of swaps for a bit. S5X's seemed out of my price range but M50's are a dime a dozen. With S50 cams and a chip they seem to make decent power for a good bit less. I have no real experience with it though.
              91 318is M50 swapped
              05 Honda Pilot
              24V swap thread
              • LowR3V'in
                • 4209
                I'm not up on s50 prices lately but an m30 all
                you need is motor mount brackets and everything else is bmw bolt on.
                Mine cost about 300-400bux and had a friend make the brackets.
                For power output vs money turbo obviously ;)
                use the 2.5 not the 2.7.
                • Chriskbmx
                  • Apr 2012
                  • 972
                  if you were to do turbo best bang for buck would be 2.7i, but i would go m30 extremly cheap swap, with insane reliablity and make decent horse power and torque.
                  • chance
                    • Feb 2012
                    • 671
                    m30 is the way to go.
                    Then down the road you can turbo it and be putting down 350-450rwhp.
                    or 560 if you are Otis!
                    1991 335is in progress
                    • Chriskbmx
                      • Apr 2012
                      • 972
                      and i feel like the m30 is just badass in general
                      • chance
                        • Feb 2012
                        • 671
                        I just got inside from driving around town in my newly m30 swapped car, and I must agree. This motor rocks.
                        And I like the fact that its a period correct motor.
                        • chop_suey
                          • Nov 2009
                          • 270
                          Ya forgot about the sbf 302, but I do like the sound of an M30, I assume best bet would be to just buy an 89^ 535i and use everything from that
                          85 325e 5spd
                          • Herr Faust Schinken
                            • Feb 2012
                            • 3580
                            does it pull like a damn train?
                            88 325is Five Speed
                            Lachssilber
                            • chance
                              • Feb 2012
                              • 671
                              Hell yea. Spins through first with ease with rolling into the throttle hard. It definitely gets the e30 moving.
