CEL is on, but the code is 1444
  • static
    • Oct 2005
    • 501
    Hi
    I recently had a bad o2 sensor which i had replaced and the code had changed to "no faults" 1444, however the CEL is always flashing when i drive
    what gives?
    Thanks
    Alex
  • lordofthewaters
    • Oct 2005
    • 714
    1444? That's the "no faults" code I believe. I suppose you could pull the ground wire from your battery and leave it off for a few minutes and put it back on to "reset". Someone else may have a better idea though.
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
    • static
      • Oct 2005
      • 501
      i did this, for 30 min actually - did not help
      Alex
      • arsevader
        • May 2005
        • 1025
        Originally posted by static
        Hi
        what gives?
        Thanks
        Alex
        Sounds like you have a short somewhere. No code being sent from the ECu but between the computer and the light there is a short maybe.
        • James Crivellone
          Head Janitor
          • 6304
          To flip the check engine light on the ECU simply grounds the side of the bulb out, one side of the bulb always has +12.
          So unless ONE wire on the ECU is grounding out (which I doubt) I bet its something internally on the ECU.
          • Dave
            E30 RAT
            • 11675
            I have the same thing happening. CEL flashes, but the code is 1444.
            Hmmm . . . .
            Current Cars
            2014 M235i
            2009 R56 Cooper S
            1998 M3
            1997 M3
            • Dave
              E30 RAT
              • 11675
              Hmmm . . . .
              Looks like I have it sorted. Coolant level sender was bad and is now lighting up the overhead. I swapped in a "new" one and now the overhead "kuhlwasser" light and the blinker in the dash are off.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • meanEG
                • Oct 2013
                • 562
                Been searching this for a while and can't see a good thread. Any more input. I have the same issues. CEL blinks intermittently, but 1444 stored. My brake linking also blinks intermittently. Ant more insight before I dig out the meter and start back probing and driving?
                Looking for late model fogs, E39 Fog lights, cool cheap 17 5x120 wheels.
                • Seawolf
                  • Feb 2015
                  • 270
                  Just to be clear here, are you referring to the actual Check Engine Light (red warning to the left of the spotlamp warning) or the flashing yellow 'CHECK' lamp between the speedo and rev counter ?
                  If it's the yellow flashing then that isn't the CEL, the 'CHECK' is just telling you that the check control has detected a fault and a red indicator should be lit on the roof check panel. None of the check panel alerts will raise an OBD I code.
                  • meanEG
                    • Oct 2013
                    • 562
                    Yea, it
                    is the check engine light. I am away from the car until Sunday, so I can't look into it until then. First priority will be to replace a bad leaking rear main seal.
