Screaching from engine bay
  • e34_spangler
    • Dec 2012
    • 311
    There was a screaching/squealing from the engine bay so I replace the old belts and now the squealing stoped but I guess the screaching wasn't in the belts all the new ones run great are tight like suppossed to be amd there the right ones so what woild make a screaching sound? Goes in and out I think I've only ever heard it when driving and not when at a stop sign or just sitting there. Thanks in advance!
    Sent from my SCH-I535 using Tapatalk 2
  • e30construction
    • Jan 2013
    • 591
    a pulley could be going out somewhere..
    93 325i 120k
    mods: straight pipe,eibach sport springs,style 54s,kamotors carbonfiber cai,
    future mods: chip, m3 cams, headers, turbo
    • e34_spangler
      • Dec 2012
      • 311
      Anyway to tell?
      • george graves
        • 19996
        You better hope it's not a timing belt. That's a belt too. If it goes, your engine goes boom.
        You can hit pulleys with some wd-40 and sometimes they will quite down.
        Originally posted by Matt-B
          A bad bearing on some rotating part on the front of the engine would be a likely candidate. Or the motor mounts could be bad and the fan is rubbing on the shroud.
          • e34_spangler
            • Dec 2012
            • 311
            Well it shouldn't be the timing belt when I bought the car the guy showed me reciepts of having a new time belt put in..
            • e30construction
              • Jan 2013
              • 591
              get some belt conditioner and spray each belt one by one and see if it stops..could also be a fan clutch..check ur mounts like he said and see if your fan is touching anything
              93 325i 120k
              • e34_spangler
                • Dec 2012
                • 311
                I was soraying belt conditioner on the old bwlts yo stol the noise but I shouldn't have to with new belts?
                • dannyyisntt
                  • 3141
                  I think it's clear that moth man is stuck in your bay. Hence the screeching
                  • e34_spangler
                    • Dec 2012
                    • 311
                    I was thinking that:p
                    • e30construction
                      • Jan 2013
                      • 591
                      if the noise is coming from a pulley the conditioner will still make it go away for a few seconds
                      93 325i 120k
                      • e34_spangler
                        • Dec 2012
                        • 311
                        Ok so sorry not a master mechanic but how do I tell if ones bad
                        • e30construction
                          • Jan 2013
                          • 591
                          spray the pulley one by one and see if the noise goes away when you hit one of them..also try spraying the fan/fan clutch..and if it goes away when you spray which ever one then theres a high possibility that the one that u sprayed and it stopped is bad
                          93 325i 120k
                          • kronus
                            • Apr 2008
                            • 13032
                            It's possible that your accessory pulleys have some mounting issue. This can happen with alternators, the rubber bushing disintegrates and the alternator goes out of alignment with the rest of the engine, putting the pulley at an angle, which can cause screeching.
                            cars beep boop
                            • mrgraphics
                              • 221
                              An incorrectly tensioned belt can do that. When installed they may have been tight, but they slightly stretched and now are mildly slipping. A re-tension of the belts may solve it.
