I got an m62 V8 with no mounting bosses.
  • CarsSuck
    • Oct 2005
    • 968
    As the title states, i acquired an M62 V8 (X5 4.4 wrecked). I'm thinkin engine swap, get home, notice that 3 or 4 bosses on one side of the block have sheared off. Can new material be welded on? Or should i just part the motor out? Looking in the ports the valves have only a sprinkling of carbon on them. How much can I get for parts like the crank and pistons? Cylinder heads are complete.
    --Will
  • e30Matt
    • 5077
    Just call up a mobile welding guy. Do you still have the bosses?
    • CarsSuck
      • Oct 2005
      • 968
      i got it from a body shop, they separated during the wreck i assume and are looooong gone.
      --Will
      • Jarvis
        • 2132
        Don't even the earliest X5 4.4i's (2000?) have the M62TU (aka single Vanos) engine?
        How would you deal with this in an E30? There's no OBD1 V8 wiring with Vanos control to convert it to.
        • E304life
          • Jul 2005
          • 123
          Yes, for the most part. There was a standard m62 in a pre production
          x5 that came through the STEP school(bmw school).
          I think the bigger problem would be dealing with the rolling code EWS.
          • CarsSuck
            • Oct 2005
            • 968
            well i guess ill just sell the heads and pistons and crank.
            --Will
