most informative article I found
I adjusted my valves this weekend. be sure you adjust them by the firing order. Also adjust the intake and exhaust side. Best advice is to use the feeler gauge and adjust the rocker arm so that it has NO play while the feeler gauge is under it. Also make sure you can slide the feeler gauge easily with a slight drag. you just have to learn as you go.
