spark plug blew out of my motor!!!
  • bitolo89
    • Nov 2012
    • 2
    so i was driving and as i start to go from a stop light i suddenly hear a loud ping noise come from the engine and suddenly the engine noise gets louder i recognized the sound and pulled over and looked and sure enough a spark plug blew out of the head. i tried looking for the spark plug in the engine bay it wasnt there and i looked in the street and i couldnt find it. should i just try and stick another spark plun in? and since i was really close to home i drove it home 3 min drive. its a '87 325is with the M20 motor
  • FLG
    • Sep 2011
    • 3165
    You could try, but if the threads are stripped chances are it will happen again. If it wasnt screwed in fully it could have possibly just messed up the first thread or two still leaving enough bite in the rest to keep it seated.
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • bitolo89
      • Nov 2012
      • 2
      yeah i was able to put a new spark plug in i turned it in very carefully seeing if there was any hesitation and there wasnt so i just tightened it and checked the othe spark plugs and replaced the spark plug wires... thanks flg
      • blasphemy101
        • Apr 2012
        • 170
        ...so torque wrenches are awesome...
        The Great Big M20 Timing Belt DIY
        Some good information I've found online (no affiliation):
        Turbo Tech (Garrett)
        Four-cycle information and cam properties for beginners (ISKY Racing Cams)
        • jhaurimn
          • Nov 2012
          • 2224
          Get a torque wrench.
          Current:
          1989 325i
          1988 M3
          1987 325ic
          Past:
          2001 330ci
          2001 M3
          • ELVA164
            • 4861
            Uh...how many times has this happened to you?
            • sweet6e30
              • Feb 2011
              • 531
              Torque Wrenching Sparkplugs ............oh LAWD.... facepalm
              my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
              • FLG
                • Sep 2011
                • 3165
                There's nothing wrong with doing so (Imo it's very good practice actually) , all things have a torque spec for a reason... Spark plugs included
                Sent from my Galaxy Nexus using Tapatalk 2
                • sweet6e30
                  • Feb 2011
                  • 531
                  if you need to use a torque wrench to install spark plugs you shouldnt even be touching a motor. END OF STORY.
                  • tightithrash
                    • 200
                    just tighten it until it starts to get loose
                    • dnguyen1963
                      • Nov 2011
                      • 2649
                      ??? You mean "start stripping the thread"...
                      For spark plugs, 21lbs/ft is the spec (not really that much). For most people, a tight tug is enough for spark plug.
                        A good pro that has done this a few hundred times can do it without a torque wrench, but if he/she is good they'll still pull out the torque wrench and do it right.
                        Spark plugs like the oil drain plug (18ft-lb) are steel parts into aluminum. It is all to easy to damage the threads in the aluminum with too much torque.
                        • txtorquemade
                          • 1758
                          /Thread....nuff said.
                          sigpic 1987 325is
                          • grays
                            • 1343
                            do not use a torque wrench
                            • FLG
                              • Sep 2011
                              • 3165
                              Exactly.
