Hi, I have a bit of a problem with a leak in the top of my radiator, I have a picture of the problem area. The yellow arrow indicates the direction the coolant is leaking out from, there seems to be a gap between that metal bracket and the block where the hoses attach. As you can see the coolant does need a flushing, another thing on the to-do list for this car. Does anyone have any experience with this particular area leaking? I'm thinking I'll be needing to replace the whole radiator (and probably renew the whole cooling system while I'm at it) but I was hoping to find any info on whether or not this could be repaired for the time being. Thanks for any and all help you can give!
