Help ID this hose in my 1987 325 please
  • chefmike70
    • Mar 2012
    • 13
    This hose goes from the valve cover
    fitting seen here under the ICV
    to this fitting here
    It is badly dry and cracked and I hope it is the root of all my evil.
    IS there a BMW part number for it? It appears to be purpose made as one end is larger than the other.
    Mike
  • e30construction
    • Jan 2013
    • 591
    ur pics didnt work
    93 325i 120k
    mods: straight pipe,eibach sport springs,style 54s,kamotors carbonfiber cai,
    future mods: chip, m3 cams, headers, turbo
    • travish325
      • Jun 2012
      • 1151
      Cant see pics but from the post sounds like the pcv hose
      part number 11 15 1 708 801 on bav auto
      • chefmike70
        • Mar 2012
        • 13
        Found it. Thanks!
          • 37833
          www.realoem.com is your friend for part numbers.
          Grover Beach, California
          BimmerHeads.com
          • chefmike70
            • Mar 2012
            • 13
            I got the new hose in and installed, car is better but not fixed. here is my continuing situation.
            Car starts and runs. I let it warm up at idle. After 5-20 minutes it will die.
            I have a fuel pressure gauge tee'd into the fuel line. During normal idle it is about 29 psi where my book says it should be. When it dies it is at 40psi and holding.
            I can undo the fuel line and bleed the pressure off and it will restart. FPR has a new vaccum line and there is fuel in the return line but it is not under pressure so I don't think there is a blocked return line.
            When the gauge is at 40 psi and the car won't start I can introduce starting fluid or fuel through the side of the intake boot by removing the ICV hose and reattaching it. The car will run for a few seconds until that fuel is spent so I know I am getting spark.
            My question is: Could the electrical signal to the fuel injectors be cutting out so they are not delivering fuel? If so how do I go about diagnosing that? Since it is an ETA I don't have a c191 as that seems to be the cause in other posts I have read.
            Here is what I have replaced with new so far:
            CPS's
            Fuel filter
            vacuum lines/breather lines/intake boot
            main relay
            fuel pump relay
            I have cleaned and checked the FPR, ICV, fuel injectors per the guidelines I have found here but they all seem fine. I do believe I need a new TPS as I don't hear a click as I believe I should- I am getting a meter today to test it to make sure.
