Oil (maybe) coming through HVAC
  • hyperaudible
    • Jun 2012
    • 16
    I've been noticing a buildup of some sort of greasy sheen on the inside of my windshield, seems to be most concentrated around the air vents at the bottom so I assume it's coming in through the ventilation system.
    I can't see anything too suspect with a visual inspection under the hood...
    Anyone experienced anything similar before?
    A leaking heater core is a possibilty
    • hyperaudible
      • Jun 2012
      • 16
      That makes sense, I'll have a look. Cheers!
      Any other suggestions?
      • Varinn
        • 780
        Not much else to consider, leaky heater core or evaporator maybe. Most likely heater core.
        1990 332i, 4 door
        2008 KTM 990 Superduke
        2018 Golf R, 6spd manual (Pending delivery)
        2017 Mazda CX-5 GT
        2007 Z4M Coupe - Sold to very nice people
        • roguetoaster
          Biggus Tippus
          • 7829
          Not getting any pooling/goop in the left hand front foot well? If you really want to rule out the heater core just loop the lines just before the aluminum fittings on the firewall/heater core.
          • hyperaudible
            • Jun 2012
            • 16
            No pools in the foot well, don't seem to be losing any coolant either. I was thinking I'll clean it well and leave the ventilation on full cold and recycle for a while and see if it stops accumulating on the glass. That should isolate the heater core yeah?
