Can I just use normal engine oil? What oil should I use? You know... the whole oil in the spark plug hole to restore compression from bad rings. Thanks bitches ;)
Will
RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
Welcome e30 (brilliantrot '90 325is) 12/23/06
DaveCN = Old Man
My signature picture was taken by ME! Not by anyone else!
If people keep quoting me in their sig, I'm going to burn this motherfucker down.
And when you put oil in and do compression test again, if compression is better... your rings are going bad correct? Or is it the other way around?
Will
DaveCN = Old Man
yeah becasue the oil helps it seal better. Has the car been over heated at all? i know my temp neddle being even with the start of the red was enough to fuck the HG
Nope. Never overheated in any way. Never been past the 3/4 mark. If you didnt see before... I put up compression numbers and I am getting a "new" engine. I just wanna see if its the rings or not. Cus if it is, I can just keep putting oil in there until I get my new engine lol.
Will
DaveCN = Old Man
As I said before, you almost definitely have a leaking headgasket. The chances of the rings failing on three adjacent cylinders is pretty slim, however a headgasket leaking between cylinders is very common.
If you really want to do a 'wet' compression test, use about a tablespoon of motor oil.
Really... it doesnt matter what it is because I should be picking up another engine real soon. I am just curious. I would doubt rings as well but you know ;)
Will
DaveCN = Old Man
Yea, then machining the head... so why not get a whole engine for cheap? And thats what I'm doing so... nobody is talkin me out of it ;)
Will
DaveCN = Old Man
Except I am replacing all the gaskets. If compression comes out good, I won't fuck with the head gasket though. Everything else...getting changed. Do you guys not pay attention to my other threads recently????????????
Will
DaveCN = Old Man
It might not have perfect compression because you didnt machine the head before putting it on. If it over heats and the head gasket blows, you need to mill the head so its perfectly flush because more than likely it is warped. You need to mill the head when you change the head gasket in any situation more than likely.
Will
DaveCN = Old Man
