I there.
I have some issue problems in my E30.
If i push the car, or i get some traffic, the temperature needle passes the middle,and in the traffic, it only lowers when the car is moving.
In the weekend i went to a trip around 25 miles, and i caught some traffic. The car had heated, (he didn´t passed the first mark after the middle one), a bit.
After i parked and went for a walk, when i return, there was some liquid from the radiator in the floor. the water came from the expansion tank, so i presumed the car got so hot that he had to release some water.
The car got a new water pump, and a new thermostat.
When i arrived at home, i´ve checked the hoses before and after the thermostat.They were both hot, so the thermostat isn´t closed.
What may be the problem?
The radiator has 19 years, and i don´t know the real condition about the radiator(if the radiator as rust and calcary(??) inside, could do a bad coolling?)
The fan behind the radiator rotates, and if i try to stop it with a screw driver, it doesn´t stop (to check the viscosity of the system??).
help?!
Thanks
help?!
Thanks
