Strut or Springs Clunk
  • monoblanco
    • Mar 2008
    • 310
    I can hear this clunk sound while driving over bumps, sometimes when I turn.
    If I push the front of the car down I can hear the clunk happening as the springs and struts contract.
    I did replace the springs and struts about a year ago, but I was not driving the car much. The clunk noise has worsen.
    What's the 1st thing to look at?
    Thank you.
    monoblanco
    www.passportsoccer.com
  • Rtheriaque
    • Apr 2013
    • 78
    Ball joints in the control arms, tie rod ends, control arm bushings, and stabilizer links.
    • N2MYE30
      • Oct 2007
      • 5536
      ...and strut bearings.
      COTM
      • jrobie79
        • Mar 2006
        • 2525
        rear shock mounts - usually causing clunking and on mine it sounded like it was coming from up front
        1991 318i ---- 308K - retired
        • 603Racing
          • Dec 2010
          • 612
          Could also be the nut on top of the strut/strut mount assembly. They are known to work loose and will clunk.
          90 325i DD/Track
          03 Durango 5.9
          Originally posted by e30mpg
          It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
